If that's a 4 way 60A Ryefield panel, where is the timer, socket outlet and the other bits being fed from?? First call is to the DNO, to find out if PME is available. If you say this set-up has been in place since the 50's, there doesn't seem to be a problem with the size of supply!! So what about the bonding of the incoming water and gas services,....none i take it??
What is needed, is a replacement Ryefield panel, can't really be having fused neutrals in this day and age.. lol!!
When all said and done, the size of the incoming supply is the least of your problems!!! By the way that DNO cable looks like a relatively new concentric cable, rather than a PILC able. So that definitely wasn't there in the 50's... lol!!
