Hmmm...seems like a toughish one.
What cct(s) and equipment does this other board feed?
Have there been any new appliances added to this cct? Anything large and potentially dodgy such as a freezer/new kettle/oven?
4 curcuits lights, ring, heating controlls & a radial with 1 fcu on it.
no new apps
ive retested everthing all hunky dory & put a new rcbo in everything works fine. only thing i can put it down to is the faulty rcbo but i still dont see why it triped when the rcd's were switched back on. the new rcbo dosen't do it. well it shouldent any way. thats why i was wondering if it was some thing to do with harmonic currents i know bugger all about them. just wondered if any of you guys could shed any light on it. but it seems not. oh well not to worry. at least I know its right and i can sleep
no new apps
Fair enough. Tested without the apps connected though? Just wondering if there was a dogdy element etc on one of the apps. Does it trip with none of the apps connected?
Did you shorten the Neutral flylead for the RCBO?
I phone Crabtree the other week and the minimum they say you can shorten it to is 150mm
what about the functional earth?
otherwise.....
no everthing unplugged & dissconnected on both counts!
otherwise.....
Actually no I didnt shorten the leads. But im glad u mentioned this as ive often wondered but decided against as they usually have crimped ends so thought best not to. thanks for that.
