Discuss ring v radial in the Electricians' Talk area at ElectriciansForums.net
if it goes out and back ( as a ring) then it will be double the length, as long as it takes the same route back. not if it returns via istanbul though.
if im running 4c 25mm swa from service fuse to new dis board(20M) and plan to run single core earth along side, what size do i need .. tn-c-s 0.07 ze....
calculator out in car, i would just run a 16mm but can i get away with 10mm along with armour????
Wired a three story house in four 32A 4mm radials as oppose to 32A rings, I really wished I hadn't, cost more, longer to run and had trouble with max Zs despite no faults found , had to knock it to 20A in the wbd
What size cpc is in 4mm? Is it 2.5mm?
Can't answer because the forum thinks the answer is too short
as for 4mm radials ived devided it up and none will be over 40m using 26A as Ib...
yes 5core swa it is but was thinking maybe cheaper to just run 16mm alongside maybe 10mm
3p/N use 5 core.
Dedicated earth and Swa as belt and braces in case some idiot decides to guess at how to make an Swa gland off...........as Wade's post this week.
oops.............wade just posted the photo honest he didn't really make that end off:)) lol
sorry mate hahahaha
5 core swa
4 core will suffice using armouring as your cpc mate as long as you gland it correctly and it passes all the relevant tests as the guys have already stated..............me.................5 core every time and dedicated earth core bolted and bonded and earthed to everything with 6mm brass nuts and bolts:)
That Earthingnuts pdf is more confusing than useful, far better to use this table when dealing with SWA CPC values and compliance's
Blue = min CSA of cables SWA to comply.
(Red) = Cable does not comply.
Table for 70[SUP]0[/SUP]C Thermoplastic PVC SWA cables.
Conductor CSA
Minimum CSA of SWA to meet 54G
CSA of armour 2 core
CSA of armour 3 core
CSA of armour 4 core
1.5
3.4
15
16
17
2.5
5.7
17
19
20
21
23
35
24
36
40
41
44
49
16
36.1
46
50
72
25
36.1
60
66
76
35
36.1
66
74
84
50
56.4
74
84
122
70
79.0
84
119
138
95
107.2
122
138
160
120
135.3
(131)
150
220
150
169.2
(144)
211
240
185
208.6
(201)
230
265
240
270.6
(225)
(260)
299
300
338.3
(250)
(289)
(333)
400
403.9
(279)
(319)
467
Table for 90[SUP]0[/SUP]C Thermosetting SWA cables operating at 70[SUP]0[/SUP]C.
Conductor CSA
1.5
3.4
16
17
18
2.5
5.7
17
19
20
19
21
23
22
23
36
26
39
43
16
36.1
41
44
49
25
36.1
42
62
70
35
36.1
62
70
80
50
56.4
68
78
90
70
79.0
80
90
131
95
107.2
113
128
147
120
135.3
(125)
141
206
150
169.2
(138)
201
230
185
208.6
(191)
220
255
240
270.6
(215)
(250)
289
300
338.3
(235)
(269)
(319)
400
451.0
(265)
(304)
452
well i dont even need the extra core , but any job most of time i notice one tied to it but if i can get 5c which table dosent metion well
salt laden area sea front
i=p/u
I'm coming over to Northern Ireland on tonight's ferry.
My genius and intellect comes cheap at as much Guinness and smokes I can consume each evening after work.
PM me for phone number.
well i dont even need the extra core , but any job most of time i notice one tied to it but if i can get 5c which cable dosent metion well
Then i would personally run your SWA cable underground in a duct, sealed at both ends with a propriety duct seal compound. And make sure you pull the cable into the duct carefully, any damage to the sheath, will allow the salt laden water to corrode the SWA very quickly!! lol!!
i punched hole through ceiling and uncovered a beam , supposed to be holding building up, didnt look to healthy
the cable is inside but so is beam
Reply to ring v radial in the Electricians' Talk area at ElectriciansForums.net
What would be the fault with a very high Zs at all sockets on a ring main, the sockets are an average of 68.10 . The lights are.67 and the is...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Hi! Is there any way to know if I have a ring or a radial circuit in a division of the house? Thanks!
HI All, I am building a new house (self build) and have my part P so am running the cabling. My reading of the regs says that any appliance of...
4K
