I use them...been using them the last few days actually, feeding cables over racking in a warehouse. Would of really struggled without them.
You can buy cheap set's for about £16 IIRC.
Infact we work in a factory where they manufacture them...the rods are pennies...
I got mine off ebay, was about ten quid and has twenty screwable segments. Don't bother using the fancy ends, generally just tape the cable on the end. Before that I used to use varying lengths of garden cane taped together. I like the sense of satisfaction I get when I've managed to route a cable through a seemingly impossible route.
I hate stud walls. If not for that middle horizontal noggin it'd be so easy to drop cables down. Unless it's also stuffed with freakin' insulation.
don't mention insulation. i quoted a job last month. 336 downlighters to be 2nd fixed. kingspan solid across all the ceilings. needs to be cut bacl min 2" all round at each point. quoted 45 mins/point. bugger ain't come back to me. thank god.
Cable rods, combined with a inspection camera, 2 of the super sets with fish tape, expensive but well worth the money in time saved.
I used to but the cheep £10 sets.. However false economy in my eyes.. Usually ended up buying one set per job as they allways snapped..
I always struggled to get my fat head under floors for a proper look, until my mate introduced me to the solution. A mirror and torch. Genius. Lots cheaper than a camera too.
Narrow escape Tel, as that's a lot of work for little reward mate.
I use draw tape/ fish tape/snake/nylon draw line....and sometimes plastic trunking lid or the odd bit of plastic conduit.....I don't like the cable rods....
If I need to pull in an armour I stick a heatshrink end cap on the end and cut it off at the other side....can stick a rope on then feed it through the end of an adhesive heatshrink cap then pull it through ductwork etc....
Rods, two pieces of tie wire one with loop and one with hook for some really awkward areas, or sometimes just a piece of string with a nut. I really need to get myself one of those mirrors on a telescopic rod, at the moment I just cut a small hole in the ceiling and stick my camera 'phone up there.
length or two of plastic capping for me i am afraid ( trunking lids! do you think i am made of monney! ). will rods hold the weight of 25mm twin and earth over 2 metres, if so i need a set.
