G
grantr37
Hi guys,
Need some advice on how to go about building this circuit.
In summary, i fear i may bore you death with the full version, i need to install a DOL with emergency stop and reverse screw capabilities onto a screw feed auger, that is operated by a 24v signal sent from the PLC after the load cells on the mixing vessel the auger will be feeding, has registered the correct weight. The auger spec is 415v, 50hz, 0.6kva (o.48Kw w/ power factor of 0.8).
It has no independent control, just a 3p + e plug tail from the motor which is mounted at the head end of the screw, circa 9ft in the air.
So far my understanding is i need to weld up a mounting bracket to mount this DOL onto and acquire a 24v relay that will need to be added to into the circuitry of the DOL along with the thermal overload.
My question is, and i appreciate the incredible vagueness of what i am asking here: - What exactly do i need to make this work, to have the auger operate under manual stop/start conditions, but also be automatically switched off via the 24v (ac/dc?) signal when the correct weight is registered by the load cells.
Can anyone assist with a drawing, spec sheet, shopping list, some more LSD, winning lottery ticket....
- - - Updated - - -
I know you all love my threads, because they are so fantastically rubbish no one ever knows what im on about, but i always like to try
can we get a photo of this machine, as well as a bit of info on what it will be mixing so that we can get a bit of an idea of the place where it will be used? this will help with design....think this one will take a few days to get worked out in spare time......would say up to a week.....so need an idea of the machine and it's purpose to work out what the requirements will end up being....
this will have to be 200% perfect
but genuinely, thats all that needs to be achieved here, i do not believe we are breaking the law. I must have explained the situation badly.
