But honestly I wasn't working live I'm not stupid. I have done before and got bolted so I have learnt my lesson. I just wanted a helping idea to fix it coz it has to be a brake in the circuit if there isn't a upstairs lighting fuse
only way to find it is isolate circuit and do your dead tests, you will then find your problem in 10 minutes
there isnt an upstairs lighting fuse .....0.o...... so how were you working dead?
i will however tell you where your problem is, its probably at the light fitting.
Had this problem before. Disc brake has been applied thus letting no power through. Doh! Sorry for poor drawing HTH!
Yep and the broke dics is the government, doing away with 100w and 60w general service lamps and making us all use poxy energy savers.
T.F. for e blag.
Thank you some one helpful and by turning off all the electic
Lol DIY ..... I hope -____-
But yeh mate electrics isn't always simple call in a trained electrican
Crikey! Who would have thought that a simple light fitting change could cause so many problems. "Everyone on this forum is so helpful" you may not think it mate but by not telling you how to put this right you are being helped, helped not to kill yourself or one/all of your family.
Get help, electricians are cheaper and less traumatic than funerals.
I wasn't working live. I turned everything on to test and there must of been a brake in the live whice touched the earth. I was thinking there has now had a brake in the circuit which I was thinking bout chasing from the main rosé the so one only was stumped due to not having roses at every ceiling light
Think you should have done your dead tests like R1+R2 and IR tests before trying to test live. Then again you probably don't have test equipment.
Sintra, don't be silly, all these newbies don't believe in MFT's or dead-tests. They aren't necessary. lol
Thought I would ask the question with the amount of Electrical Trainee that's flooding the trade.
No electrician will diagnose a problem they cannot see via a forum. As this is an "electricians forum", there are lots of things we discuss, but in this case I would strongly recommend that you get a qualified electrician to sort this out. Even if you managed to get it to work, it doesn't mean it would be safe.
