i dont cut notches in neither i just simply asked if these plates are ok if there is not 50mm from either side when i put an hole in the joist are the plates ok under regs etc etc. not nitpicking about the wording i use if i was asking on my punctuation and grammer then i would use an appropriate forum not an electricians forum. cheers
how to win friends on a forum. :hanged:
i know i have just read it back and not sound good sorry ppl it wasnt meant how it sounded im crap at this writing lark as you my have guessed lol, just trying to get my head around this and cant see in the regs about the metal plates to see if they are ok to use or just a waste of time, money and are not even recognised as things to use when the joist thru hole is gunna be less than 50mm either side. cheers
Never mind mate, continue to come here and we'll have you talking like Mr Cholmondley Warner in no time at all, it's all part of the service :)
One of my sons things was double negatives- I haven't got no money for example. Used to boil my wee, so I killed him.
I think a metal plate would be perfectly acceptable to protect a cable less than 50mm from the edge of a joist. If you think you can hammer a nail or put a screw through the flimsy ones then you need thicker ones (or a lighter hammer!)
Or a shorter nail
- - - Updated - - -
Or a shorter nail
Why would the hole be less than 50mm if you've drilled it
onions i mean like e.g if i say drill a 25mm hole in the middle of a joist thats around 100mm which would leave 37.5mm at top and bottom something like that if this makes sense i asked tutor this question and he just said use these plates but i wasnt convinced that these would meet regs etc so i asked on here.
The regs book likely wont tell you what you should use,you wont find the solution in there in a hurry
It may tell you that a cable has to be mechanically protected from nails or AK 47 rifle bullets or weeping women but not what to do about it
