Also, how do you intend to support the cable correctly throughout its run?
You are allowed to run sheathed cables, that are unlikely to be disturbed, for up to 5m without any intermediate support.
EDIT: Vertical runs that is :wink_smile:
The point raised in an earlier post about the cables bridging the cavity gap and causing damp patches is very valid.
Also, don't forget those unseen knife edged wall ties which can slice through insulation and leave you with loads of trouble in the future when the damp gets into the conductors!!!!
If cables run in cavity walls contribute to moisture transfer, the same would apply to the cavity wall ties that you mention :ihih:. Also, with judicious installation, the cable should not be in a position to touch the outer wall.
I personally think that of the 3 reasons that have been mentioned (that are against the practice of running of cables in cavity walls) the only valid one is the fact that the cavity could well be filled with insulation in the not too distance future. Given that the exorbitant pricing of gas and electricity means people are looking at all and any means of cutting energy usage, then this is more of a 'When' not an 'If'.
Cavity wall ties are supposed to be designed to drip in the middle of the cavity which then goes to the DPC and out through the weepholes. Big loads of brickies muck can cause a problem though.
Ok, how about if the wire is higher on the inside travels down a little and then exits through the external wall? Surely the damp won't transfer then?
Fair point, well made.
I still maintain that if the cable is/was installed properly (with no slack) then it should not even be touching the outer wall. Even so, the insulation at a later date makes this a no go for me.
Can you point me to that in black and white mate. Not distrusting you, I'm just curious as it would mean that for the majority of work I do (domestic only), fishing down an internal cavity would be permissible.
If you can reliably run cables inside wall cavities without touching the outer wall, then you must be a very skilful person. My immediate thought is how can you possibly know it's not touching??
On the subject of the tie bars across the cavities. They will normally be installed on the level and have a central section which is designed so that moisture does not track across.
cavity drops--
the outer brickwork is sometimes pourus sometimes not so
theouter wall may face the rain, sometimes not
i rewired an old house in ringwood hants
i dropped the ringmain cables down the uninsulated cavitys either side of the fireplace the outside wall got a LOT of rain the red bricks were shot (it ws built in the1920,s
the old wall paper by the sockets got wet almost immediately
i pulled the cables up and chased them in the plaster no more damp
Well the cable will run vertically for about 4 metres inside 25mm conduit attached to the outside of the house.
Do you think it will need additional support?
For additional support I could add a round inspection cover half way up the run and use a cable tie to give the cable some support although for a run of just four metres is this really necessary?
Hi Murdoch I'm still around, I have one or two customers and I still work with my old "master electrician" as I like to call him from time to time, he still makes the most beautiful containment systems I have ever seen, a proper old school craftsman and I'm lucky I met him.
Depends on the top edge that the cable is resting on, as it enters the drop! A sharp 90 degree edge, then yes it would!!
As to the original thread title, I see that the old wives tale about a cable touching external faces in cavity walls is still alive and kicking!! I wonder what they have to say about all the muck that gets trapped on the steel wall ties during the erecting of any/every cavity wall i've ever seen?? Now if what is being claimed for cables is correct, then just about every cavity wall ever built will have some degree of damp entering the house!! lol!!
cavity drops--
If the outer walls are shot then there shot, nothing you can do about that. But they haven't used porous bricks for external walls, for god knows how many years now!!
I'm not convinced by this cables etc argument.
99.999999% of damp problems are caused from running water down the wall from broken gutters etc
Just checked in the NICEIC Snags & Solutions book 2. It's all down there as to why you should not run cables in cavities. The corresponding 7671 BGB numbers are referenced too to verify why it's bad practice.
