J.C.E
I want to install a couple of ceiling recessed speakers in my bedroom.
apart from speakers and speaker cable what do I need?
Happy cutting the holes and mounting the speaker (like a downlight) then I guessing I run a 2 pair cable from each speaker down to some kind of unit?
Planning on using speakers for my tv and iphone (for music)
so if place 'unit' by my tv, what connection do I need between these, and I guessing the iphone pairing can just be aux or even bluetooth?
any help would be great
No its not, I have speakers in my bathroom ceiling. Seems the logical place to put them.
I have just installed a similar set up on wednesday, client supplied this amp to control speakers and input devices http://www.visionaudiovisual.com/techconnect/tc2-amp2/ and he supplied matching ceiling speakers and for a budget set up (£180 bundle) it works well
i love ceiling speakers.
and the correct, insulated plasterboard ceiling acts as a great speaker box ! LOL
i recommend using a SONOS AMP and JBL speakers.
my whole house is set up like this :)
Here's mine. They are yellowing slighty now, as they are about 15 years old. They are waterproof and primarily designed for boats, but work perfectly well on land. They are supplied through cat5 cable that runs throughout the house which is fed from the speaker outputs of my stereo via the patch panel under the stairs. :) There are 'box' speakers in the other rooms, which I have put little switches in so I can control the sound in each room. These are controlled by a small double-pole switch outside the bathroom door.
Edit:
Here they are, where I bought them from: http://cpc.farnell.com/visaton/fr-16-wp-cl/loudspeaker-waterproof-ip65-6-5/dp/LS03711
Oh yes, and I use some of these to control the stereo from different rooms. :)
PowerMid XL Remote Control Extender PM10C: Amazon.co.uk: Electronics
Don't forget to run 2 speaker cables to each room as you will require 2 x speakers per room!!
Or 8-core cat5, then you can supply 2 x speakers and send 2 x inputs back to the stereo, all done one tiny cable :)
Installed some speakers in a kitchen extension this week. Got the chippy to make a insulated box that fits in the ceiling around the speaker. They sound really good!
I've fitted a Sonos amp and Blue cube speakers ceiling speakers and it sounded amazing, I used a stereo speakers one for the ground floor and another for the first floor so had to run 2 pairs of cables to each speaker.
Speakers through cat5 ... That's a first lol
Its only conductive wire, and works perfectly well! :)
(I did wonder if the stereo would get upset at having a lower speaker resistance than it is expecting, by running several speakers in parallel, but 15 years on it still doesn't seem to care.)
