A
atm84
Can anyone explain the difference between a Switch fuse and a fuse switch unit I know that one has the fuses in the switch and the other had the switch and fuse in series. Can anyone tell me why you would use one and not the other. Cheers
A "fused switch", the fuses are on the switch blade carrier. A "switched fuse" the fuses are separate from the blade carrier.
Tony, thank you for your reply. I visited this forum for some advice, are you able to provide any or not?
Handbags, handbags- we electricians know more than the basic s..t you will get on google, plus on this forum we are real- not some wannabees
thanks bluey, why do some people find it so difficult to offer help then, i only came on for some advice, it doesn't look like i will find it here so i will look elsewhere.
The purpose of the forum IS to help fellow sparks, but not to spoon feed the Lazy. Tony offered a major part of the answer and you seem a little reluctant to do anything yourself.
