may seem like a very stupid question to some but the truth is i dont know, do blanking plates count as acessories and have safe zones in the same way a socket does?
thanks
A blank plate would indicate that there is wiring at that point and therefore the safe zones in relation to that point should be observed.
Whether they are observed is quite another matter!
new safe zones can be created as well by the presence of accessories...
this would need to be observed on both sides of a partition wall...
Not with you. They don't provide safe zones- the wiring to the outlet that has a blank plate should be wired with the safe zones in mind.
Safe zones are defined by the location of accessories (and the walls), horizontally and vertically from an accessory is a safe zone, therefore if there is an accessory (a blank plate) on the wall the H and V from it are safe zones.
i think what the OP meant was that if an accessory had been removed and replaced with a blank plate, would that position still count as a reference point for a safe zone.
well...you`d think so...i mean what if theres cables still present within the zone of the blanking plate...
its the cables that safe zones apply to...
accessories just demonstrate the presence of cables and provide a reference point for the safe zones (150mm)...
was thinking of if cables had been previosly surfaced mounted and needed chasing in, and no safe zone avalible you could provide one with a blanking plate if needed
i meant horizontally and vertically ( hows that fr spelling after 7 pints) from the blank plate, same as fr a sochit, sockcet, whatever.
Do you mean that you would install a box with a blank plate over it and run the cable through it, in order to chase a cable where you need to.
Yes I suppose so. So long as there are cables in a flush box visible behind it otherwise someone might think it was just covering a damaged wall and remove it.
