M
marshr02
been digging around to try to avoid this post - in case I'm making a fool of myself again - but here goes anyway. Just like IR tests am I right in thinking the Zs value needs to be obtained with the 2/3 way switches in their different positions? Otherwise how do you find a high impedance issue in one of the strappers that takes Zs too high - and which might not be tested depending on the switch positions? Cheers
The issue here is not R2 continuity, but R1 - in particular the R1 strapper that doesn't get tested when Zs is measured AT this pendent - so AT this pendent there will be two Zs depending on whether the 'good' R1 strapper is in cct, OR the 'bad' R1 strapper is in cct.??
