P
paul35
Hi all. Can anyone tell what size the earth cable should be from CCU to the earth rod. To clarify I am installing an TT system in a two bed regular house.
what size is the usual main earth conductor ????
and the one stated in the OSG ?
LOL i know.the OSG size shown for TT is not correct.
Unprotected means without a sheath.OSG states it should be 25mm sq. if unprotected. Not sure what they mean though, would that mean clipped direct. 16mm sq. if protected against corrosion. But it says you can get away with 2.5mm sq. if protected agains corrosion and mechanical damage. Why is there such huge difference. Can the 2.5 carry the fault current anyway
