J
jon090
Hi,
A customer of mine (a restaurant owner) received a letter from the electrical distributors saying that because the building was once two separate premises and they have now been knocked together to form one open plan room, there is an issue with having two separate electrical meters and isolation points - should the fire services need to shut off power.
They explain that to meet minimum requirements each meter must be clearly identified and point out where the other meter is. In addition to this, there must be "cross bonding between the earth and neutral conductors" - I'm struggling to work out exactly what that means?
Live and Neutral into 1st unit...................TNS Brown phase.
Live and Neutral into 2nd unit .................TNC-S Black phase lol
Highly unlikely but good luck:)
Na i checked that.. Its bell wire
lol.
Wasn't being critical mate I was just making up a scenario where each of these 'previous rooms' were fed from a different phase with different earthing arrangement but now their both in the same room.
I still dont understand whats required? What needs cross bonding? (It was 2 seperate houses initially - its now an open plan room and hes paying 2 seperate elec bills one for each meter yet its one property)
It wasnt a trick question, was just looking for some clarity on the matter to make sure i was doing things correctly as i havnt come across this before. apreciate the help
I'm suprised that they allow 2 supplies in one room TBH, if the load in that room could be handled by one meter I would have thought they would disconnect one and make you connect the supplies from it to the other board, I'm not suprised they want the earthing linked, imagine if there were a bit of plastic pipe in the plumbing somewhere and the earths from the 2 sides were either side of the plastic bit and there was a fault and you touched either side of the plastic, potential problem for sure, hypothetically disasterous although also possibly no issue, not worth the risk though hence them suggesting the earths are linked, at least there are trying to cover any problem that could arise.
I hear, thanks for that i just wanted to make sure. Dyou rekon 10mm bonding between each earth blocks? The run is about 20meters.
Do you know which phases each supply is on? And also what earthing arrangements are in place for each supply.
How do i check to know what each supplys phases is? Will go back and look at the earthing arrangements. I think they were both TNCS but ill double check.
Double Check with the dno, give them a ring and get clarification of what they what. It could be that you will end up with a parallel feed as such if on the same phases or maybe a touch potential of 415v if on different. If you get the scope of the works from the dno the onus doesn't solely lie with yourself.
