44ALLAN
Do you know which phases each supply is on? And also what earthing arrangements are in place for each supply.
Post 3 and 7
How do i check to know what each supplys phases is? Will go back and look at the earthing arrangements. I think they were both TNCS but ill double check.
44allan - the two meters are about 20 meters away from each other which would make that test difficult to do.
or a wander lead....Maybe you could use a standard 13A mains extension lead and a couple of R2 socket adapters to connect your meter between two socket outlets, one on each meter
whatever its down to the DNO to change the arrangement, its their incoming supplies
