d1scv
Didn't like to say anything till now- BUT one bit of the puzzle is missing.
I agree that I cannot put my finger on it.
As Yooj stated,the system earth would still be TNC-S The earth spike being a suuplementary earth for the line spiked neutral,this has been a recomendation of the IET for these installations for improved safety
It may have prevented the daughter from having the shock whatever the system fault turned out to be
My blood also boils when people do not read and properly understand the message. I did not play with the electricity. the fault was in the loop from next door. he had electricians working there, not me. also the electricity board did a very very thorough check of my house. every thing was ok.
Sorry to hear about your daughter's bad experience momin.
I've got one point:
whether this was a broken neutral/earth in a pme context, or a shared/looped earth between neighbouring dwellings, or both .... it's the DNO's responsibilty to provide an (external) earth path for every installation. If that path was broken due to a broken neutral then the liability is theirs; similarly, if an installation is without an earth path because it it shared with an adjacent installation and disconnected there (for maintenance or modification of that installation), it's still the DNO's responsibility.
Maybe a solicitor would be more appropriate than an electrician in this context.
be carefull using an earth rod in conjunction with PME as a fault on the network resulting in a lost neutral near your property may result in all your bonded metalwork becoming live!!!!!!!!!!!!!
An earth spike [question] would only serve to reduce the possible effect of a lost neutral ?
One more thought, in all my years I got 2 belts, both from borrowed neutrals.
230AC. Both threw me BIG time- certainly did not grab me.
I thought only DC grabbed you, and AC threw you off.
I am going to be argumentative for the hell of it
I say 400 + volts AC will grab you
Care to prove me wrong with a pratical demonstration?![]()
I was unable to move until I concentrated hard on dragging my arm away whilst roaring a shout.
Trust me- I finished up in a heap a good 12 ft away.Sorry but I dont see how an electric shock can "throw you across the room"....I've had a few minor belts in my time but I've not been "Thrown across the room".....and yet everyone else who gets a handful claims they were "Thrown across the room".
the real questions that I would be asking, would be to the DNO in terms of why was the Main Earth to Momin's terminated in the neighbours house,
Yooj
