Discuss Where to find a ducting 'Y' pice with a non return valve?? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Does anyone know where I can get a ducting 'Y' piece with a non return valve?
I have looked all over the internet and cant find one, perhaps the answer is to use both?
I need one of these:
which has this:
Cheers all...
Thanks JD,
Thought that might be the case, but also thought someone must have invented one!!
Buy both and fit the non return valves on top of the fans, not at the Y bend. Had to do a job like this not to long ago. Paid for a inspection of the local building dept at the council to double check how it was done. Passed fine.
Reply to Where to find a ducting 'Y' pice with a non return valve?? in the UK Electrical Forum area at ElectriciansForums.net
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
I've just started using the NAPIT forms for EIC's and EICR's and they are a bit cumbersome to be fair. Does anyone know which observation is for a...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
I came across this controller that is used to heat a tank located in the loft of a house. The controller seems to be faulty as all 3 temperature...
