A
Some are like that but tends to be those who have to hide their own incompetence a lot of us do give regular good advice feel free to check my post history we don't have to do this this we do it to help those who are learning .... but sometimes the level of questioning is far below the competence that the OP should have so occasionally we will express this if not just for the OP safety ..... i don't expect to see a question from a fully qualified electrician asking how to do a basic insulation test ....believe me we get that level of questioning so yes sometimes talking down is justified... ive had enough apprentices to know what level and type of question to expect from each level of apprentice experience so when the questions get stupid then we will treat as stupid.I agree with boffy35, most people on this forum dont offer real help or advice they just want to take the mick and slate others to make themselves feel competent.
I would of liked to but that's all we had pal thanks for your reply
Nothing wrong with the layout i slightly disagree with the separate earth bar comment as this would hinder testing by giving parallel paths on earth as you seem to be extending circuits and would have to disconnect each earth if commoned up here.
My only critique is your core markings as has already been noted you can't have L marker on Neutral and earths as the L identifies them as Live... check table 51
Hi mate thanks for your reply I see what you meen now pal it would look so much better but my gaffa is a mingebag lol cheers for your reply
Is that a 'mingebag' who gives you a job ?
hi mate thanks for your comment its much appriceated cheers palApart from the comments on cable marking, that's a neat and well executed installation for an apprentice. It makes a pleasant change to see a bit of care and attention put into a job!! Well Done!!
Scatts, Farnell, RS Components .... never had any trouble getting the correct gear, i wouldn't even entertain using general electrical wholesalers to source my gear for panel building.
All good advice Darkwood, but at the end of the day, he's an apprentice and wouldn't know too much about the sort of panelwork you're involved in. He get's given the materials and instructions on how to markup/identify the cables. What you can see, as soon as the cover of this JB arrangement is removed, is that a bit of care and thought has gone into it's installation...
Personally i don't like to see cable ties to dress cables, certainly not in a consumer unit or distribution board setting, but in a JB as we have here, i don't see much of a muchness of them being used or not.
