R
Rs electrical
I've had a LED lensor H7r for about 2 years and it's been a good little torch apart from battery life as it only has 3x AAA and a lot of plastic clips which have broke over the years and is now held together with tape.so I've been looking for something with a bit more juice and found the zebralight H600 series.I went for the H602w which is a flood only lamp and a rechargeable 18650 lion battery which is equivalent to 4x AA.
Had it for a week now and it's far better than the led lensor much higher lumens, more battery life and more comfortable for about the same weight. The light is 120 deg spread which is perfect for work indoors and has a number of setting right up to 1000 lumens which compared to the 170 lumens and focused beam on the lensor makes it much better for changing boards in cupboards working under floors and in lofts.
I payed £75 for the torch and then about £15 for a good 18650 lion battery so it's not cheap but worth it IMO as I use it so much it just ends up staying on my head for most of the day.
