E
Engineer54
Not quite, if the accident would happen obviously it would be proven by investigation that it's has been manufactured wrong, but I would imagine if you would try to get your money back in the shop, saying it's getting to hot, they would try to blame it on you, on interfering with manufacturer. Although it probably depends on the people. I had spent half hour in the shop trying to prove that the rope light doesn't work because they have cut it in the wrong place![]()
You would need to remove the Din Rail assembly when fitting and bringing cables into the CU, so you have already interfered with how the manufacturer presented the CU. Trimming and cutting of RCD tails to size etc will in no way whatsoever, affect any warranty or put any onus on you for doing so. Providing of course that all subsequent connections are electrically sound.
Retailers and wholesale counter staff are generally muppets at the best of times, it's just another occupational hazard that all electricians have to contend with!! lol!!
