J
jasonmizen
Evening all,
was wondering if there's anything else out there rather than using dry lining boxes or the good old fashioned nogging when boxing up on new builds.
cheeres
Surface mounted pattress boxes?
I don't really get the question, is there something wrong with metal back boxes or fast-fit boxes?
I think he means rather than metal knockout boxes and dry liners, as pointed out there are surface boxes, but hey, who would want those on a new build
Duraplug extension leads with stickyback pads onto the gyproc.
But let the taper finish and painter do the first coat of paint.
Boydy
I think he means is there an alternative to dry line boxes for sockets in a timber framed house, other than putting in noggins and using metal boxes. That's my interpretation!
MK at one time did metal clips which converted their metal zic boxes for plasterboard mounting.
Boydy
I've never seen any need to use anything else. I prefer to use galvanised boxes where possible, otherwise fastfix boxes are available just in case. I find both are as adaptable as I need them to be.
On the job I'm on at the moment the accessories are extra deep so we've been cutting away most of the back of the box and wrapping grommet strip edging around it so the accessory pokes into the void behind, then the boxes have been fixed into the panel using screws through the inside edge of the box. Not ideal IMO but it's one way of doing it.
I've seen dryliners with a lug cut off and a screw put through into a neighbouring timber....
Flange boxes wouldn't work either, nothing to get a decent grip on...
