M
monkeyelectric
Evening all! what pat tester do you reccommend? i'm after something low cost and easy to use, has'nt got to be too special as its only for testing a few items in rental properties
I've seen the kewtech one attachment, are they any good?i was looking at a kewtech pat tester last night too but its£350, not too bad i suppose and it will pay for itself eventualy, i don't fancy buying second handBetter off buying something second hand if you can or I have seen a few products that you attach to your 17th edition tester whcih gives you all the tests needed. Google it and you should find a few to choose from.
Chris
Hi Jim if you dont mind I would like to know how you could use that with my 1552 many thanks in advance.
Chris
[FONT="][/FONT]Yes plaese mate i'd like a look at that if you can get hold of it, i've just started doing periodics for an estate agent and in some of the houses there are washing machines, fridges and stuff like that but i did'nt much want to fork out loads just yet, been a tough januaryThey're ok but you can build one from a trailing socket and some old test leads.
That's what I did, my mate brought a Kewtech one and I just copied the connections.
Unfortunatly I can't remember the connections (not well enough to publish one here anyway!).
I will get hold of the unit and let you know the config if your interested.
I also use mine as a R2 wander lead attached to a small extension lead, the NIC assessor was quite impressed with my self build kit (so i can't be to bad)
Jim
Yes plaese mate i'd like a look at that if you can get hold of it, i've just started doing periodics for an estate agent and in some of the houses there are washing machines, fridges and stuff like that but i did'nt much want to fork out loads just yet, been a tough january![]()
Oh yeah looks easy to do, cheers for that, i'll probably get some 4mm sockets and fit them to the side of a trailing socket, be just like the kewtech then more or lessWell...
If I can remember correctly (don’t sue if I’m wrong!!)….
You’ll need
1 trailing socket
2 old test leads
Cut off the PROBE part off the test lead and discard,
leaving the lead with the 4mm (I think) plugs (the ones that plug in to the multitester / multimeter etc)
You’ll need to join 1 lead to the Line (Live / Phase or what ever it is this week) AND neutral.
The second lead goes to earth
Now just follow the testing instructions on the Kewtech website!
http://www.kewtechcorp.com/products/pat/patadapter1.htm
Hi mate
I use the seaward primetest 50 costs about £260.00 inc vat, like you i only use it every now and again works fine and doesnt break the bank check ebay out new ones on there.![]()
