Discuss best wood bits?? in the Electrical Tools and Products area at ElectriciansForums.net
Ive got to say it a 20mm wood bit is the answer lol. No seriously I agree with MDJ the cheapest as you will surely hit something,
Armeg do a wood beaver thats nail proof, its blue, and works well although I have yet to test its kryptonite abilities.
I also have a bosch flat bit that is slightly (deliberately) twisted, and is also painted blue and its brilliant.
neither were cheap. Aside from that I am with Mike (or is it Mark) - I just buy a 229 piece set from Wickes, etc for 20 snots and chuck them away when knacked up
yep armeg are good, self pulling bit to quick, I'm on my second one now i use slightly older one near block wall or if i know a nail might be near. bosch blue tip spade ones are my second choose but don't last as long
best ones are those borrowed from a plumber. don't matter then what happens to them.
Auger bits are fastest if you have a nice torquey drill. Toolstation do them cheap enough so you won't cry if they get munched up.
Or cheap spade bits kept going with a file or grinder.
the more expensive the bit , the sooner they sniff out a nail.
considering this cruel yet true anomally i find it best to just stick with the £1.50 spade bits from screwfix
impossible lol
I always use Milwaukee ogre bits, they go through joists in seconds and they are pretty tough against impact! You just have to put your drill on Gear 1 and they glide through. Armegs ogre bits are pretty good too! Milwaukee bits are only about £21 for 4, well worth the money I normally buy a new set every couple of months as I end up losing them or eventually they get blunt but they definitely earn their money first!
Well, they are touted as "nail proof".
I quote:
"http://www.buybrandtools.com/acatalog/armeg-nail-proof-wood-beaver-16mm.html"
to me, nail proof infers....they are nail proof
I quote:
Yes, the black WoodBeaver drill bits are definitely sold as being Nail Proof. I would be happy to put you in touch with a very knowledgeable Armeg rep if you are having problems with them?
Hi , no need but thanks , I think they are great. Aspertions hsve been cast as to just how nailproof they can be (not by me ).
:stooge_curly:
Rollocks, I have never seen a bit which will not blunt after hitting a nail, that is false advertising, even the very best bits will end up blunt afterwards, the good bits can be restored by sharpening them again but no bit is nail proof, impossible if a wood bit, definately could be if made for metal drilling though.
ogre bits are deadly!
Been using the Irwin blue groove bits, 8 quid a set and they sharpen up a treat too when they go blunt unliike those red armeg stubbys sometimes they sharpen up ok but 2 holes later and they are fubar again
If you want to drill deep holes fast, you can't beat an Auger bit .... both Bahco and Irwin are decent, if pricey. If the material is only thin, you'll get a better result with a flat bit ...... If you want a good finish where the hole would be seen, try a forstner bit which will produce the cleanest hole.
I've used 100's if not 1000's of auger bit over the years doing site work timber frames..
ive just bought the red armeg and have been very disapointed. I'll be using augers again next time
Armeg 'Wood Beaver' Bits are brilliant. Only available as a hex fitment but can be used with an 18V Cordless with no power loss.
Other brands are available, under the general term of 'Flute Auger'.
Sorry. I'm regretting ever buying the wood beaver bits.... Bloody useless,
the shafts bend, the go blunt quickly and are a load of carp... Won't be buying anymore
Ive had a problem with a bent shaft, probably due to my own brute ignorance using it, but other than that have found them great to use. Had them a good few years and they just keep going and going ...... dont seem to have any issue with then blunting!
Reply to best wood bits?? in the Electrical Tools and Products area at ElectriciansForums.net
I’ve got a makita wall chaser. What is the best one. Mainly 20mm chases.
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
I’m just trying to find out which tool, bag, bucket, would be best for a young trainee electrician. He hasn’t got many tools yet and we struggle...
Hi all, our summer house had a FuseBox consumer unit fitted last year and the guy who did the work has retired. nothing wrong with the install...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
