Discuss Heaters from ring in the UK Electrical Forum area at ElectriciansForums.net
so informing the customer the running costs of convector heaters is not something you would do?
couple of minutes chat and thats it, hardly a hardship.
let them find out approach.
Well i would and have done and many people are surprised at the cost of heating properties with electric at peak cost.
How do you go about working out the running costs then?
I assume you factor in the insulation of the rooms to be heated, number of external walls, any other heat sources, energy tariff they are on, efficiency of the heaters, size of the rooms?
Not to mention the average householders complete inability to use storage heaters properly.
Economy 7 and 10 also have much higher peak costs, so for a small property it may not be worth it depending on how much they use the heaters and usage during peak times.
ROINTE radiators are very good and on a plug too too !! Or you can fcu them.
Someone has been influenced by all the company snake oil hype!! lol!!
These things as i remember, are bloody expensive radiators (around 600 quid for a 2KW radiator) and are actually no better than any other manufactures products.
Heard all this old hype before, like any electrical radiator/heater, you basically get 1KW of heat output, for every KW of input. Anyone telling you any different, is is giving you a load of snake oil....
Reply to Heaters from ring in the UK Electrical Forum area at ElectriciansForums.net
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
Hi, I recently moved into a house with electric storage heaters and am looking to replace them with electric radiators. Gas and oil are not viable...
Evening all, Been to a job on Fri where the customer had a condition report completed. Two of the remedial identified was that there were too...
