Everytime I get a plumber they are either ridiculously expensive, leave something dripping.... or both!!
I dont touch plumbing in my house as both times I've attempted it I've just got into a right pickle. I dont understand water, with electrics you do things a set way and it works, with plumbing I do it exactly as stated and then I get ... drip, drip, drip!!!
Anyway.. I needed the copper pipes channelled innto the wall rather than stuck on the outside and boxed in. They go directly from the stop cock (where the main bonding is attached). The chap said he would use copper. I get home and see a great length of plastic pipe stuck in the wall all the way up to and into the ceiling.... I have just spent the last hour getting a 10mm cable from the stop cock to the start of the copper pipe, had to drill a downlight hole in ceiling to access it!!! Luckily I'm just about to have the ceiling skimmed!!
The point is if I didn't know (a little!!) about earthing and bonding my house would now be left without all the water pipework bonded (there might be some parellel paths but thats besides the point)!!
Ggrrrrr...... I'm disappointed with tradesmen at the moment!! Apart from electricians who always do a good job :biggrin:
