H
Hogshaw
I am trying to source a timer I need the time to come on at 8.00am for 1 second this will trigger a contactor and I need the timer till come on again at 9.am for a split second to kill the contactor has anyone ever come across these?? If so would it be possible till post a link. Thanks
Because I have a stop button and if A1 is constantly fed from 8.00-9.00 I've no way of deactivating the coil? Thanks
you can set those timers to any amount of time you want, we built a photography film developer out of an old record player connected to one of those, it would spin the disk for a few seconds then stop then respin etc etc, so it should do what you require it to. A trip to your local maplins for a chat with the staff there may also help.
You could use a din rail impulse contactor/relay and a din rail pulsed timeswitch....each time the impulse contactor get a 1 sec pulse from the timeswitch, it changes state, ie 8am 1 sec pulse, impulse contact stays on until another 1 sec pulse is recieved, as so on.....you over ride switch will be breaking feed from impulse contactor, to main operating contactor.
