I have been given a tasty basement job in Fulham
The lighting is by a lighting designer
AV guy to cover lutron RA2 controls- me to 1st fix
Some of the lighting is spec'ed to be 0-10v
1) what is the advantage of 0-10v (as the wiring seems more invloved)- just smoother dimming?
2) is it a case of taking 230v feed>> lutron 0-10v module >> looped in and out of the light fitting drivers- then take a 2core flex from the 0-10v module looped in and out of the light fitting drivers (I am under the impression these 0-10v modules are too big to fit in some light cutouts- so best to locate these remotely in cupboards?
3)there is also quite a bit of 12v light fittings (for things like stair lights and external)
again I haven't done too much 12v/24v apart from the odd bit of LED srip
is it common that most of there fittings wire is series and to take a 2core flex from each light to a remote located driver and then red to black connect these?
Look forward to responses!
J
J
