Hi
Is it safe to use a 10 Amp Extension Lead with a 7 Amp Car Battery Charger? Apologies if sounds crass - just need reassurance it's safe please. Thank you.
If you are saying you have an extension lead that can take 10A and the battery charger only draws 7A then it will be ok, from a current carrying capacity.
If the extension lead is coiled up while you are using the charger then heat from the coiled up extension lead may cause a problem.
Oh.... and, welcome to the forum mate...
what he says. ^^^^^^. if its a coiled lead, unwind before use unless you prefer it melted.
If you are saying you have an extension lead that than take 10A and the battery charger only draws 7A then it will be ok, from a current carrying capacity.
Thank you. Yes, the extension lead is rated 10 Amps and will be used laid out flat/fully extended with a CTEK 12 Volt/7 Amp Charger.
hang on.that 7A is probably the current at 12V. the current drawn through the 240V lead will be 7/20.
Yes it will be 7A at 12v, the 230v input will be considerably less.
The charger almost certainly outputs at 12v, 7A. The 230v input supplies an isolating transformer from which the 12v is derived. The current on this 230v supply will be nowhere near 7A, the 7A is the output only.
Ok. So the 10 Amp Extension Lead, fully unwound, will be safe to use with said charger?
