Discuss 1000 feet aluminum run in the Electrical Forum area at ElectriciansForums.net
PGT96drvr
I want at least 200 Amps at a Building 1000 feet away from my feed. I'll be running Aluminum wire and will only use 120V equipemtn(welder, compressor, etc). I'll be running 240V to the building.
My question is: Which diameter/Gauge wire will I need to accommodate these needs?
Thank you very much
Thank you very much
First you will need to install conduit, then at every 200 feet you have to have a pulling point. Most guys set junction boxes above ground. The wire size for aluminum for a 200 amp panel will certainly be very large in size, something you couldn’t buy from Lowe’s or Home Depot. I believe you would have to use 350mcm and 4 inch conduit, PVC preferably
why not use copper. smaller size required? alternatively transform up at supply end to 1kV, then back down at load end. much reduced current.
Reply to 1000 feet aluminum run in the Electrical Forum area at ElectriciansForums.net
