Discuss 1000 feet aluminum run in the UK Electrical Forum area at ElectriciansForums.net
PGT96drvr
I want at least 200 Amps at a Building 1000 feet away from my feed. I'll be running Aluminum wire and will only use 120V equipemtn(welder, compressor, etc). I'll be running 240V to the building.
My question is: Which diameter/Gauge wire will I need to accommodate these needs?
Thank you very much
Thank you very much
First you will need to install conduit, then at every 200 feet you have to have a pulling point. Most guys set junction boxes above ground. The wire size for aluminum for a 200 amp panel will certainly be very large in size, something you couldn’t buy from Lowe’s or Home Depot. I believe you would have to use 350mcm and 4 inch conduit, PVC preferably
why not use copper. smaller size required? alternatively transform up at supply end to 1kV, then back down at load end. much reduced current.
Reply to 1000 feet aluminum run in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm a hobbyist without formal training. I'm looking to power audio/video equipment over several hundred feet of extension cords. I have 2...
Hello all. I am trying to get 125 amps 3 phase back to a paintball field to power an electric air compressor. I have a 3 phase 120/240v PG and...
Metal building with living quarters the panel is on the outside and about 20 feet away from new build that will be 2x6 what type of shielded wire...
Greetings, I'm a EE and have installed many electrical systems but am now dealing with my first large 3PH install on our property. I'm not...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
