120W LED Corn Lamp Replacement
Hi Guys, I have been asked to change Metal halide lamps for LED E40 Lamps in Floodlight fittings. The manufacturer recommends not to fit lamps above 60watt to enclosed fittings, due to overheating. Is there a fan or a way around this. These lights are used all over the garage warehouse & outside as well. All floodlights inside are obviously facing downwards, not a good idea. Thanks in advance for your replies.
A bit strange, really. I'm pretty sure a 120w led corn wouldn't produce as much heat as an equivalent 400w metal halide......with ballast.
