R
rmsmidlands
Hi guys this is my first post great forum tho, got called to a house a few weeks ago one spotlight not working in the bathroom,
4 12v fire rated recesses down lights each with their own transformer, tested the fitting and no power blown tranny, thought great nice easy one, did a visual inspection of the cables in the loft all fine, did a megger test jon the circuit just encase all fine, earth continuity is good as is zs,
So I replaced the fitting as the old one was looking a bit rough and te customer would have rather me just fit a new one anyway, job done,
Anyway two weeks later I get a call the spotlight you fitted has gone tried a new bulb and it still doesn't work, so got to go back tomorrow and have a look just thought I'd put this one out their and see what you think it might be as I'm a bit stumped as everything tests ok on the circuit, ???
Firstly dont believe anyone who tells you they've fitted a new bulb....check it for yourself....an awful lot of 'new bulbs' were fished out from the back of a cupboard. Had a run of 4 transformers fail for no obvious reason once...leading to all the usual 'must be something wrong with your wiring' comments....there wasnt and the fifth tranny has been working for several years now....just coincidence or a bad batch.
Worth bearing in mind that most electronic transformers only give an output reading if there is a load connected....this one fools many into thinking the tranny has failed.
thesed bloody cock-up 12V and a tranny fitting want consigning to the obsolete bin. over heated connectors, tranny and lamp failures, dump 'em and fit 230V GU10 LEDs.
We've had it with them now....last spring we persuaded a regular customer to change all his GU10's to LED....at a cost of over 700 quid,all starting to fail....25000 hours my arse!...One lamp even caused an earth fault .....After a long rant the manufactuer has agreed to replace the lot.
Tbh I stay away from using them hence why im not very well clued up on them, only fitted it due to him insisting like for like, should of just walked really lol, and I never trust anyone who says they put a new bulb in lol got caught out before with that one, it's a mr16 bulb if i remember correctly it was 30w, think I may just do what you guys say and fit a 240v gu10 spot,
I think I've had it with 12v as well, fed up of the constant problems
What make was that then? And what price were they?
ie, were you stung by buying cheap, or was this a quality manufacturer getting it wrong?
Lamps were fusion brand.....not cheapies.
One of the lamps developed a short onto the metal casing,and in an earthed downlight was continually throwing the RCD...about half of them have now failed or partially failed....they were fitted around 8 months ago.
Speaking to the manager of my local Wilts and he hinted they were going to start phasing their stock out and eventually stop selling 12v downlighters :icon4:
