- Reaction score
- 25
I have got my test on the 27th for the 18th edition I am struggling a bit to study the book is there any tips and tricks I should know ?
Discuss 18th Edition in the Electrical Forum area at ElectriciansForums.net
I'd recommend not leaving any unanswered as you work through them, as if for whatever reason you don't go back, you've guaranteed 0% for that question, as opposed to a minimum 25% chance or like you point out probably 50% chance as two of the wrong options are typically easy to spot.if you have left a couple un answered, when the time is running out and you are still not sure, discount the couple that are obviously not correct and guess one of the other 2. you have close to a 50/50 chance of being correct.
It's all part of the "entitlements" culture... you're "entitled" to turn up with 3 mins to spare because there's no law/rule to say otherwise. "Common sense" was outlawed around the same time... on the basis that it wasn't common.Also, this might seem obvious to some but many people don't seem to manage it.
Get up EARLY on day of test, shower, coffee, relax a bit.
turn up to test centre with at least 15 to 30 minutes spare.
arriving refreshed and in plenty of time, WILL get you a better result than screeching into the carpark 3 minutes before you should be sat down.
please don't take the above personally, I don't know your age or your work ethics.
I have noticed that quite a few, often but not only, 18 to 30's seem to turn up to everything either JUST on time or slightly late.
Re-familiarise yourself with the book, what chapters are where and roughly what's in each capter and appendix just to speed up looking things up.I have got my test on the 27th for the 18th edition I am struggling a bit to study the book is there any tips and tricks I should know ?
Hi all, are you allowed to write notes in your 18th edition book please?
much appreciated, thankyouDepends what test centre you take the exam at. some allow you use your own books where you've tabbed them up and written notes. At the centre where i took mine, they supplied us with clean copies to prevent cheating as people had previously been caught.
Reply to 18th Edition in the Electrical Forum area at ElectriciansForums.net
