Discuss 18th Regulation 411.3.4 in the UK Electrical Forum area at ElectriciansForums.net
Afternoon all,
Have a quotation regarding garage lighting which requires alteration. It’s a set of flats with a seperate large garage area which id class as commercial hence not needing an rcd as reg Regulation 411.3.4 states only in domestic.
The head of the flats is saying it’s classed as domestic area.
Board is mcbs but unsure I’ll squeeze a RCBO. C
Can you also just cover your own alterations with RCD or does it now have to be at the origin? I’d read on this forum it’s changed
Thanks in advance
Regulation 411.3.4 has no mention of installation method anyway?!
It doesn't have to, as far as I know (Don't own a BBB) it just means all lighting circuits in a domestic property must have additional protection, regardless of installation method.
If outside of a domestic environment an you had T&E buried in a wall less than 50mm it would need the additional protection because of a different regulation.
Thanks guys for your input.
If a alteration takes place on a lighting circuit do you need to cover the whole circuit by means of RCD protection or just your additional works?
Thats how I read it and as it’s clipped direct I’m just trying to determine if it’s a commercial area.
Is it being used for commercial purposes, is it solely occupied by businesses who pay business rates etc etc.
Or is it a bunch of domestic garages belonging to domestic properties/ intended for use in association with domestic properties?
I'd bet if you looked at the tenancy agreement for the flats, commercial use of the garages is specificaly prohibited.
That will be why the head of the flats is saying it’s classed as a Domestic area
Why pick over the difference of interpretation, seems it very likely to be domestic, just rcd protect the circuit with an independent rcd or rcd FCU above the board if you can
Then rest easy!
If in doubt just do worst case then you should not be caught out
Unless the cost is prohibitive that is, which in this case it seems trivial
Reply to 18th Regulation 411.3.4 in the UK Electrical Forum area at ElectriciansForums.net
Evening all. I have a question as I can’t get my head around something with solar PV I’m going to be working on a new build in a couple of...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
  • Locked
5K
Short Version Is it permissible to have 2 feeds to 2 separate consumer units in a detached garage? Is it permissible to run SWA underground...
Hi I’m looking for advice on the following: I’ve yet to contact my local council about installing a light in Zone 1 of my bathroom (this due to...
