B
Brian246
I currently have 4 double sockets on a 20amp Radial, I am looking to get a small air con unit (2.5kw I think) to cool a 5m by 3m space. Bearing in mind the only things plugged into the sockets are 2 PC and 2 Monitors at most, do you think a 20amp feed is enough?
It is a right pain to try and run another feed and I would like to have the sockets and air con unit on the same radial.
Thanks in advance
Thanks in advance
