Recently installed a 2 way varilight v-pro dimmer switch using the master and slave modules. Worked fine and then several hours later it stops working. Spoke with Varilight and they said switch the circuit off at the consumer unit and put back on again. I did this and FOR NOW it works.
- Has anyone else had an issue with this and if so what was the long term solution to resolve this?
- Also any insight as to why the dimmer modules would stop working and require a reset at the consumer unit before functioning correctly again would be appreciated. The technical team at Varilight couldn’t give a clear explanation
