N
NickD
I was replacing a cracked 2-gang switch earlier today, domestic hallway switch forming part of 2-way switching setup for the upstairs landing light with a 1-gang at top of stairs. (2nd gang on 2-gang controls hallway light.) Red/black T&E (black permanent live, red switched live*) and R/Y/B+E 3-core at upstairs switch; R/Y/B+E at downstairs switch (plus red/black T&E for hallway light on 2nd gang). So far so bog standard.
But on inspection, the yellow wire has been disconnected at both ends, and upstairs the black (permanent live, or at least should be) has been disconnected and hacked short at both the switch and the junction box intended to feed the light. Obviously the 2-way lighting is not working; the red & blue out of the 3-core have been wired to put the upstairs and downstairs switches in a series which is fed from the permanent live on the hallway light at the downstairs switch. So the landing light only works in one of the four possible switch up/down combinations, plus the live on the upstairs lighting circuit is borrowed from the downstairs (or if you prefer say it's on the downstairs lighting circuit but neutral borrowed from upstairs).
I was gonna continuity and IR test the 3-core then try putting the 2-way lighting back into service, but a little voice in my head said maybe someone had left it that way for a reason by someone who knew what they were doing (particularly because the innards of the junction box for the lights, plus another one next to it, were neatly done).
I had a sudden vision of the yellow cable being nicked by a screw going into metal wall studding or something similar and decided that as the client wasn't that bothered about it I would leave well alone.
Apart from bodgery and incompetence, can anyone think of a specific reason why that hacked-off black live feed and disconnected yellow would be this way?
(*I know other way round is preferred)
