Discuss 2 way switching configuration HELP in the UK Electrical Forum area at ElectriciansForums.net
Simple one here, the inch wire you mentioned dropped on the down stairs switch is the loop live feed ( com ) you just need to put this wire link back from com on the two way to the live red on the other switch.
Thank you all for your help.
It appears one of the 2 T&Es at the downstairs switch had been used as a 3 core strapper with no CPC.
What appeared to be a broken CPC at entry to the box was infact a live return.
The 'link' must have been the broken piece.
Have you sorted it now? because really it is a school boy issue, very simple really, just incredible you are struggling.
Thanks MDJ, as I said above, one of the 2 T&Es at the downstairs switch had been used as a 3 core strapper with no CPC.
Reply to 2 way switching configuration HELP in the UK Electrical Forum area at ElectriciansForums.net
Hi All, Pretty comfortable with wiring lighting until I came across needing to install 2 way dimming with a Retractive switch. I didn’t even know...
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
