Simple one here, the inch wire you mentioned dropped on the down stairs switch is the loop live feed ( com ) you just need to put this wire link back from com on the two way to the live red on the other switch.
It's all looking decidedly dodgy to me , best idea would be to rewire it from scratch .
Thank you all for your help.
It appears one of the 2 T&Es at the downstairs switch had been used as a 3 core strapper with no CPC.
What appeared to be a broken CPC at entry to the box was infact a live return.
The 'link' must have been the broken piece.
Have you sorted it now? because really it is a school boy issue, very simple really, just incredible you are struggling.
Thanks MDJ, as I said above, one of the 2 T&Es at the downstairs switch had been used as a 3 core strapper with no CPC.
