K
keith915
Father has just bought himself a 2nd container for a bit of a workshop. He'd like to board the sidewalls but doesn't want to drill any holes... Any ideas of ways to fix 18mm ply board to the sides? Gripfill?! haha
2x2 or 3x2 wedged horrizontaly this would also give space for insullation mind a vapour barrier as condensation will no doubt be a problem
Grip fill 3x2 battens to the sides then fix the ply to those. There's no way they'll drop off once the grip fils set properly.
Cheers guys, think the batten idea, then board, then a small wedge batten after to take any strain off the gripfill might be the way to go. He probably wants to hang all his tools off them so a wedge batten will take the weight off.
Just need to design an install for it now. 60metre 10mm armoured. To rod or not to rod, that is the question. Haven't the bible with me at the moment to look up the requirements.
Trust me, once grip fill has set there is no way its moving, especilly as the load is shear load. Got a 450mm deep shelf in the garage and the 3 brackets are screwed to roofing battens grip filled to the sectional concrete. On the shelf i've got 4x5litres oil, 3x5litres screen wash numerouse cans of sprays ets. Not gone anywhere for the last 3 years
my mate's a plasterer. he'll dry line it for £200. then nothing can be fixed to it. lol
keith915,
telectrix,
