Discuss 230-12v 600va transformer in the UK Electrical Forum area at ElectriciansForums.net
B
brizospark
upon removing a 230-12v 600va transformer from a large chandelier type light fitting (40x20w bulbs) and seeing the large, around 10mm cables from the secondary side of the transformer this got me thinking - if the is running at full capacity (600va) the current output on the secondary side would be around 50amps.
Now I know that the energy cunsumption at the 230 side is around 800w (just over 3 amps) but surely not really safe to have 50amls potentially in these fittings, particularly when the earth leads at these are 1mm at most?
It is not usual for one leg of the secondary of the transformer earthed, therefore the secondary has no reference to earth, in the event of a fault of one leg of the transformer to earth on the secondary side nothing will happen.
QUOTE [but surely not really safe to have 50amls potentially in these fittings,]
which fittings ?
The full current is NOT in all fittings anyway
need more info ?
please elaborate !
Reply to 230-12v 600va transformer in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
Our old Friedland chime all too often now emits a only faint "ding"- because the person at the door (usually a delivery driver) just "dabs" at...
Hi all, first post so be gentle... I've recently decided to replace the MR16 50W Halogen bulbs in the bathroom with 5W LED ones. I'm aware of the...
