Discuss 25kv generator cable size ??? in the Industrial Electricians' Talk area at ElectriciansForums.net
can anybody tell me what size sy cable I need for a 25kv 3 phase temp generator please to power a 3 phase machine lathe
Hi mate.
Show us your calcs for the cable size and we can confirm that they are right, if you want.
36 amps load current per phase so go from there.
I've no idea the ccc of sy as it's not recognised in bs7671 as it's classed as a non British standard cable But most manufacturers claim it's to bs en 50525-2-11
Why SY cable mate? Have I missed something?
Reply to 25kv generator cable size ??? in the Industrial Electricians' Talk area at ElectriciansForums.net
wiring a 480 volt 3 phase 114 amp generator to run 2 machines. Both machine nameplate 480 v 3 phase 50 FLA. What size wire and over current...
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
Hi All, I've bought a 12ft Catering Trailer that is mainly fitted with LPG Equipment, but Electrics are required for 1x Undercounter Fridge, 1x...
Hi, thanks for reading this. Ive been asked to look at a job where the DNO connection (single phase 80A TT) is a long run to the final circuits...
