I am not a fan of crimping big cables like 25mm as I feel its just not the same as a continuous piece, 16mm I will crimp, but 25mm I just get a little uneasy about it.
Rockingit, you have a good point about the rating of the heat shrink.
God help anyone that needs to through crimp anything from 25mm to say 400/600mm then...lol!!
Crimp ferrules are rated the same CCC or higher, than the conductor they are designed/manufactured to accommodate... I've seen conductors stretch, way before a crimped connection will fail...
All LV insulation heat shrink tubing i've ever come across has had minimum XLPE insulation rating 600/1000V. To the best of my knowledge, there is no such thing as PVC heat shrink. Even the heatshrink cable sheathing with internal adhesive is of XLPE in construction...
I suspect that the most widely used heatshrink type is polyolefin.
However, pvc is available:
PVC Heat Shrink Tubing from Allied Wire and Cable Distributor of Heat Shrinkable Tubing, Sleeving
As are many other materials:
Heat Shrink Tubing (M23053) from Allied Wire & Cable | Distributor of Tubing, Sleeving & Spiral Wrap
Do you have a link to XLPE heatshrink (not just heatshrink for use with XLPE cables)?
But is heatshrink actually tested and rated as an insulator? If so, surely it would need a VDE / dielectric style rating? Not sure.
That's the very reason I use SA tape, because it is VDE rated at over 1000V and in order to remove it you would need to destroy it. I never heat shrink in line crimps, only lugs.
My point isn't that you can't GET rated heatshrink, I just wonder what the stuff in the box in my van is actually good for, given that an average pack from an average wholesaler has absolutely no information whatsoever.
There are electrically resistant heat shrink materials, but really most of them are going to be insulators at the very least.
I have just looked through a heat shrink reference table and one of the silicone rubber heat shrinks has these specifications:
Insulation Resistance: 1 x 103 megohms ( m in )
Elongation: 600%
Shore Hardness: 40, 50 and 60
Temperature Range: Max 250°C Min -80°C Short Duration 250°C
Dielectric Strength: 18kV/mm
Ozone Resistance: Unlimited
Ok, well in a not particularly scientific test, I've just grabbed a length of what's in the box in the van and shoved 1kV across it, clips next to each other....515M. Guess that's my answer, then.
Been crimping cables up to 240mm for yrs ....lugs or through crimps they achieve the same result - through lugs are more reliable if done correctly than any terminated set up up, why crimp-lug for a nut/bolt connection giving more points of failure when you can crimp, heatshrink and environmentally seal leaving a safer joint all round from moisture and dirt.
You seem like you don't often work on big cables so lack the confidence in the gear you use. Its true in that incorrect crimping tools lugs etc do account for may failures but as i said choosing the right set up will give a very good connecction.
You need to be very careful if you are comparing European Heat shrink tubing with the American stuff. They have far too many different variants, many of which is the thin walled stuff with a 150V/ 105+ C insulation and a 2000V dielectric strength. European heat shrink will generally be, standard wall 600/1000V/120C with a 20 to 25000 V dielectric strength.
As i stated, ALL shrinkable tubing/sleeve will be of a X Linked make-up, so it's not going to be PVC but a hybrid, otherwise it won't be shrinkable. No i don't, but Cross linked Polyolefin is in the same family as Cross-Linked Polyethylene, and so i class them all for convenience, as XLPE.
Having said that, there are many different heat shrink compounds that are used for electrical sleeving/tubing, that cover a whole host of environmental needs/requirements...
Armoured sub main. Where consumer unit is going to be mounted I cannot terminate the armoured directly into the board. Therefore am mounting a large jb behind where board will mounted. Then running 25mm tails into board.
Was going to have a Henley block but client plans changed making it very hard to access. Therefore needed to crimp.
mount the junction box close to the consumer unit run the 25mm armoured to it gland it and dont strip the sheathing from the cores run the cable complete with sheathing into consumer unit.
fit a plastic gland of appropriate size to protect the cable from mechanical damage as it leaves the junction box
