S
Simon Hall
I got sent to change a 2d light fitting when I took the cover off the light came on but then off again so I got a new lamp and put it in still didn't work any idea what I would be? Then on one that I took the working lamp out when putting it back it did not work again, any ideas thanks
poor connection/s . could be lamp not pushed in correctly.
You have an emergency light fitting there sometimes the electronic gear needs resetting (Turn the power on and off) or the electronic emergency control gear as packed up completely
If it has packed up the control gear is a stock item at edmundson electrical so no need to swap the whole fitting. But as tel says check the lamp holder connections.
I recognise that fitting its one of City Electricals Tamlight Em fittings , Put a few of them in and nowt but trouble from day one , bet its the control unit ...
Yes I had to change the control gear as well always depends on the condition of the fitting though, if the lamp holder is brittle and the shade as gone yellow might as well change the whole light fitting , I.ve taken the control gear apart just to see what was going on inside and found the component burnt out
The amount of times I had to go back and change those poxy fittings and it meant a 200 mile round trip as well , and the arguments I had in City's about them , they went in as communal lighting for a managing company on 2 blocks of flats ,,, utter crap,,
it will be the inverter that is gubbed , i have changed loads of these its always the inverter , kill the power and the light will --- on , turn the power back on and it wont invert bk to normal , cheaper to buy a new fitting than ordering new gear tray
it will be the inverter that is gubbed , i have changed loads of these its always the inverter , kill the power and the light will --- on , turn the power back on and it wont invert bk to normal , cheaper to buy a bew fitting than ordering new gear tray
Definitely not cheaper to buy a new fitting . And it's alot quicker to swap the gear tray.
