N
Norn Iron
Hi Guys need a bit of expert advice and guidance. I have been asked to do a bit of work at my friends new office premises. The office is located inside a warehouse and is Fed via a 16 Way 3 Phase Distribution board with a 35mm 4-Core SWA.
However the Dist board is almost full and even after stripping out some old supplies that are not required I will not have enough room for some of the new circuits that are required. This is where I require help, Is it possible for me to either
A. Run a set of tails from one of the 3 Phases in the Main switch with a Neutral and Earth and install a single phase Consumer unit..... or
B. Run a set of tails from all 3 phases with a Neutral and Earth and install another smaller 3 phase Dist board.
Bearing in mind the Mains powering the 16Way Dist board already installed comes from a load centre at the far end of the warehouse.
I hope this all makes sense and look forward to your guidance and advice, Thanks in advance.
