Discuss 3 Phase heating coil in the Industrial Electricians' Talk area at ElectriciansForums.net
ASBTTE
Hi. I'm making a 3 phase furnace with heating coils. Total power rating is 5 KW. I have to make one heating element for each phase. How do I split the KW rating? Will it be a straight 5/3? Also when calculating the resistance for each heater, should I calculate based on 220V(single phase voltage in India) or 440V (3 phase voltage)?
Reply to 3 Phase heating coil in the Industrial Electricians' Talk area at ElectriciansForums.net
I know the effect of a lost neutral (floating neutral) on a 3 phase system, and the theory of why the line voltages can vary. However, I have...
I have a single phase stainless steel pasteuriser that has two control boxes attached to it. One box houses the control for the electronics and...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
How can I convert a 3-phase (220 volt 5.6 kw) pizza oven to 1-phase (220) 2 heating elements, no motor.
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
