John-
Jan 13, 2019
198
42
103
Uk
Hi
Did some small works recently on a farm building, and the origin of the suppky is via the TPN isolator in the video. But it wont budge.
Any advice please?
I am extending the lever all the way out and then pulling down. I did not want to force it in case i broke sonething. It is the feed for the entie site.
Cheers
Jon
You need to close the cover.
Hi
Any advice please?
Cheers
Jon
video not working, plz see image’s . Btw door was not secured correctly, hinges were not engaged. Cover cannot be secured fully. I should also say it is stuck on, not off.
B3CED994-5584-4A77-B748-3EFDA163882E.jpeg95A77774-4AC9-4ABA-9576-2CDB9C41FE95.jpegC7BF762F-34FA-4FAE-86F3-574831527EA5.jpegD78F5709-33F2-4E07-8E28-C0EB3A4844BC.jpegEDE5A8ED-3116-457E-AAEA-48168F6BC24B.jpeg
Yes I can see from your video it is on. What is wrong with the hinges.
Reactions: John-
Nothing is wrong with the hinges the door cannot be put back on properly unless the isolator is in the off position somebody has taken the door off and energised it and then loosely secured the door back on afterwards. I canot switch it off though to put the door back on properly. The mech near lever locks it off, not on.
Sorted it. I am guessing it had not been operated in years, a littje more brute furce needed. All mechs are well lubed, so must have been the the fuse blades.
Reactions: happysteve
I was just about to say give it a bit of a tap.
Nice one.
315 amp retractives will take a hell of a lot of manual force to damage.
  • Funny
Reactions: ferg and DPG
Dees are good.... Dees are good......... R.C.D's are good!
I’d be slightly worried with the overcrowded lug connections & sizes 😂😎
  • Agree
Reactions: ipf, UNG and pc1966
Reactions: ipf and DPG
Poor man's busbar chamber...
farmer's busbar, more like...
As a rule, when it comes to outlay, they is tight, man.
Reactions: pc1966
Australia
GLENNSPARK
G
Uk
325A MEM stuck Isolator
John-,
ipf,
