- Reaction score
- 4
Left over stock, all brand new unused in boxes. Looking for £150 job lot. £10 postage or can be collected
Description:
Description:
- ELG-75 series is a 75W AC/DC LED driver featuring the dual mode constant voltage and constant current output. ELG-75 operates from 100~305VAC and offers models with different rated voltage ranging between 12V and 48V. Thanks to the high efficiency up to 90%, with the fanless design, the entire series is able to operate for -40℃ ~ +85℃ case temperature under free air convection. The design of metal housing and IP67/IP65 ingress protection level allows this series to fit both indoor and outdoor applications. ELG-75 is equipped with various function options, such as dimming methodologies, so as to provide the optimal design flexibility for LED lighting system.
- Constant Voltage + Constant Current mode output
- Metal housing design with functional Ground
- Built-in active PFC function
- Class 2 power unit
- No load/Standby power consumption<0.5W
- Type A: IP65, Lo and Vo adjustable through built-in potentiometer
- Function option: output adjustable via potentiometer; 3 in 1 dimming(dim-to-off); Smart timer dimming; DALI
- Typical lifetime>50000 hours
- LED street lighting
- LED architectural lighting
- LED bay lighting
- LED flood lighting
- Type "HL" for use in Class I, Division 2 hazardous (Classified) location
- Comply with Class II applicatio
