G
goldie
Hello all.
Would you say main protective gas bond would be okay to install within 600mm on entry to the building although the pipework branch is external by meter cupboard? There is about 2 metres of gas pipe outside including the first tee.
Also standard fire rated downlight to be fitted in bathroom (not ip rated) but will be positioned above 2.25 metres and my belief is they wont be affected by the damp atmosphere etc.
