G
goldie
Ok cheers Njg28, sometimes takes a while on here before some1 gets to the point. input appreciated.Hello all.
Would you say main protective gas bond would be okay to install within 600mm on entry to the building although the pipework branch is external by meter cupboard? There is about 2 metres of gas pipe outside including the first tee.
Also standard fire rated downlight to be fitted in bathroom (not ip rated) but will be positioned above 2.25 metres and my belief is they wont be affected by the damp atmosphere etc.
Bond ideally within 600mm of entry to building BUT before 1st branch / T
Above 2.25m is outside zones so no need for IP rating. Personally I prefer IP rated in bathrooms in any event as I find some non-IP downlights can suffer cosmetically due to steam. Then customer blames you for fitting them!
